Build CML VM and Activate and then Import to ESXi ?
SJNIII
We are looking at purchasing 4 to 5 CML Personal Editions to use in our VMware Lab.
The Lab is air-gapped with no internet access.
Can I build the CML VMs on an ESXi host that has internet access, activate / register the product, then export the VMs off the ESXi that has internet access and import it to our air-gapped ESXi host?
thanks
balaji.bandi
it should work as long as VM ID S/N not changed.
BB
SJNIII
Thanks.
Follow-up Question
Once the VM is moved to to our air-gapped ESXi host and powered on, will the VM ever need to connect to internet again ?
I read on another forum that the CML VM can be disconnect for up to 7 days until you're required to re-authorize.
If this true, we cannot use CML Personal Edition as there is no way to get an internet connection.
