Cannot load YAML properly
pcai
Visitor
Hello all,
I am writing to report a specific issue I've encountered while importing our lab environments into Cisco Modeling Labs (CML) using YAML files. On the switch, the configuration for VLAN 140 is only being partially loaded, the process stops abruptly after the standby version 2 command.
This causes the system to skip all subsequent configuration lines, including the rest of the HSRP settings, the remaining VLANs, and the entire OSPF section.
I looked into potential causes and found suggestions that invisible control characters might be getting inserted during the YAML generation process, but a manual inspection of the files didn't reveal any formatting anomalies or hidden characters.
Any thoughts are welcome.
Thank you!
pcai
Visitor
balaji.bandi
can you post YAML file
BB
