CML 2.2.3 OS upgrade fails due to CentOS 8 being deprecated
jospanier
Cannot upgrade OS in CML 2.2.3 anymore, as CentOS 8 has been deprectated on 2022-01-31.
All CentOS 8 mirrors are gone. Fetching packages in CML-controller fails.
What to do now?
Martin L
I think I read you should not be doing any CentOS updates; go to CML CNL forum and search or post your question.
https://learningnetwork.cisco.com/s/topic/0TO3i00000094ZjGAI/cisco-modeling-labs-personal-community
Regards, ML
**Please Rate All Helpful Responses **
I follow instructions in https://developer.cisco.com/docs/modeling-labs/#!in-place-upgrade
specifilcally the step "Upgrading the Base OS - Recommended"
also posting in learningnetwork
telestrial2020
Hi jospanier,
I experienced that problem as well.  Make sure you have full administrative e.g. super user (su) rights for the directory or folder where you have downloaded the reference platform refplat*.iso.  I imported the new .ova file into vmware and had to do a lot more adjustments/modifications than earlier releases.  I had to expand the hard disk because the default was about 10 to 16GB, I also changed the operating system choice from CentOS8 to Rhel 7.   Make sure the hardware compatibility matches what you need.  I changed mine to workstation 16.2, the default was Esxi, also make sure that the Virtualize Intel VT-x box is checked.   I had to tweak all of these things to get a sensible install.
