Showing results forĀ
Search instead forĀ
Did you mean:Ā
CML Activation Product
Raph B
Hi, I have an Issue activating CML, the installation went smooth, I can now log in into CML software on my browser.
The issue at first was that my VM couldn't access internet, Now I fixed it.
When I enter my software license, i just wait for a good 2 minutes and then this message appears
"Communication Timeout - Will Reattempt Automatically
The Product Instance was unable to register with Smart Software Licensing due to a communication timeout. Ensure that the Product Instance can access your selected registration server.
The Product Instance will automatically reattempt registration and will remain in evaluation mode until it succeeds."
If anyone could help out, it was quite a sum to pay
Raph B
Update 1 : I tried to look for some solutions so far :
I'm running on "cml2_p_2.6.1-11_amd64-11.ova" with "refplat-20230117-fcs.iso
I tried to ping 8.8.8.8 to check if my VM has internet, it works , Also tried the "curl" also works.
It looks like my browser for some reason doesn't access internet or the Cisco Smart service is down somehow...
Raph B
Update 2 : Ok now CML doesn't work anymore for some reason
I don't have any IP addresses to connect to the web browers
