CML not showing nodes | Refplat already mounted
juankarlos31
Hello Community would really like your help.
Just purchased and installed CML, I only have the unamannaged switch and the external connector. I found similar folks with the same issue and they just had to load the ISO to the drive, which I have done already, what could be the issue.
The name just to confirm is right is like this: refplat-2023xxxx-fcs --> replaced some number with x
Installed on my PC with the provided OVA in VMware workstation player.
CML registered and authorized.
Under CML/Tools/Diagnostic everything is showing green
Thank in advance for any very much needed help.
Torbjørn
Which version of CML are you running?
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
juankarlos31
Hey Torbjørn,
I downloaded 2.6.1 and after trying different things, decided do re download the ISO, it seemed that even though I was doing everything right, the ISO I guess was corrupted and with a fresh file everything worked.
It was odd as I was getting no errors during the install, so did not think that my ISO was corrupted.
All good now.
Thanks for checking!
Torbjørn
I'm glad the issue got resolved. Have fun labbing!
