CML errors after changing IP address
pfyffe361
I've been running CML 2.2.2 under VMware fusion for some time and recently moved. Unfortunately, in the new house, I'm not able to use the same IP address for the CML server. The web interface / login screen comes up, but comes up an error message "e.response is undefined". Snapshot attached. The web sysadmin login simply says "error" when trying to login.
I have access to the console interface, and sysadmin gains access to the command line. I just don't know where to go from there.
Peter
balaji.bandi
pfyffe361
didn't make any difference
I connected up the other router that I had been using previously and it served up the original IP address for the CML server. I was able to access both the admin and sysadmin accounts through the web interface when I used this router. Unfortunately, with that setup, I am unable to access the Internet.
When I go back to the new router setup, the original problem I described here occurs.  I am using a firefox bowser on a mac book pro running Catalina 10.15.7. There must be some kind of logs that are accessible from the console level that can help with this issue.
-Peter
