CML Spanning-Tree Lab Issues
etodust
Frequent Visitor
Frequent Visitor
I'm doing a simple practice lab. The lab is designed to not give you all the information you need. I am trying to do a lab a day in preparation for getting my CCNP. (Still a ways off) This is also my first experience with CML and the IOSvL2 nodes. I'm hoping that my CML purchase wasn't a mistake.
Problem: All switches consider themselves to be the root bridge.
DLS1 is set to root primary, DLS2 is set to root secondary. I'm using VTP, and all VLANs created on DLS1 propagated appropriately to the other switches.
My first instinct is that these IOSvL2 nodes don't do what I think they do. If someone could confirm the difference between using this and using a virtualized Catalyst 2960, and what problems I might run into. CML only gives us a single option for managed switches. All I want to do is practice CCNP level networking, but Cisco has made it so difficult and expensive to get this stuff setup. I finally got CML setup on VMware, and now It seems like its gonna be a long road of headaches.
I would greatly appreciate any help on this. I would be happy to provide more information or logs if necessary. I feel like this problem may just stem from a fundamental misunderstanding of CML.
Thanks!
etodust
Frequent Visitor
Frequent Visitor
For anyone wondering, I found the problem. I did not configure encapsulation mode.
After configuring dot1q for all active ports, root bridge is now on a single switch as it should be.
Never give up!
8 Replies 8
balaji.bandi
Never seen this issue  - i am using vios_l2 Software (vios_l2-ADVENTERPRISEK9-M), Version 15.2
it works as expected. (if each switch is acting root, meaning there may be some issue or they do not participate in STP.
post all the device show run and show spann
BB
DLS1#show run
Building configuration...
Current configuration : 2886 bytes
! Last configuration change at 01:31:20 UTC Sun Oct 3 2021
version 15.2
service compress-config
hostname DLS1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode pvst
spanning-tree vlan 100,200 priority 24576
interface GigabitEthernet0/0
switchport mode dynamic desirable
negotiation auto
interface GigabitEthernet0/1
negotiation auto
interface GigabitEthernet0/2
negotiation auto
interface GigabitEthernet0/3
shutdown
negotiation auto
ip forward-protocol nd
ip http server
ip http secure-server
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS *
* education. IOSv is provided as-is and is not supported by Cisco's *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any *
* purposes is expressly prohibited except as otherwise authorized by *
* Cisco in writing. *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
end
DLS1#show span
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 28772
Address 5254.000e.cba7
Cost 4
Port 1 (GigabitEthernet0/0)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Address 5254.001d.f206
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Gi0/0 Root FWD 4 128.1 P2p
Gi0/1 Desg FWD 4 128.2 P2p
Gi0/2 Desg FWD 4 128.3 P2p
VLAN0100
Root ID Priority 24676
This bridge is the root
Bridge ID Priority 24676 (priority 24576 sys-id-ext 100)
Aging Time 300 sec
Gi0/0 Desg FWD 4 128.1 P2p
VLAN0200
Root ID Priority 24776
Bridge ID Priority 24776 (priority 24576 sys-id-ext 200)
Aging Time 300 sec
DLS2#show run
! Last configuration change at 01:35:49 UTC Sun Oct 3 2021
version 15.2
hostname DLS2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree vlan 100,200 priority 28672
negotiation auto
negotiation auto
negotiation auto
shutdown
negotiation auto
ip http server
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
end
DLS2#show span
VLAN0001
Cost 4
Aging Time 300 sec
Gi0/1 Altn BLK 4 128.2 P2p
VLAN0100
Bridge ID Priority 28772 (priority 28672 sys-id-ext 100)
Aging Time 300 sec
VLAN0200
Root ID Priority 28872
Bridge ID Priority 28872 (priority 28672 sys-id-ext 200)
Aging Time 300 sec
ALS1#SHOW RUN
Current configuration : 2739 bytes
! Last configuration change at 01:29:08 UTC Sun Oct 3 2021
version 15.2
hostname ALS1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
negotiation auto
negotiation auto
negotiation auto
shutdown
negotiation auto
ip http server
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
end
ALS1#show span
VLAN0001
Cost 4
Port 2 (GigabitEthernet0/1)
Address 5254.000f.7c79
Aging Time 300 sec
Gi0/1 Root FWD 4 128.2 P2p
Gi0/2 Altn BLK 4 128.3 P2p
VLAN0100
Root ID Priority 32868
Bridge ID Priority 32868 (priority 32768 sys-id-ext 100)
Aging Time 300 sec
VLAN0200
Root ID Priority 32968
Bridge ID Priority 32968 (priority 32768 sys-id-ext 200)
Aging Time 300 sec
ASL2#show run
! Last configuration change at 01:28:57 UTC Sun Oct 3 2021
version 15.2
hostname ASL2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
negotiation auto
negotiation auto
negotiation auto
shutdown
negotiation auto
ip http server
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
end
ASL2#show span
VLAN0001
Cost 4
Port 3 (GigabitEthernet0/2)
Address 5254.000b.491e
Aging Time 300 sec
Gi0/2 Root FWD 4 128.3 P2p
VLAN0100
Aging Time 300 sec
VLAN0200
Aging Time 300 sec
I am running the same version as you, vios_12-ADVENTERPRISEK9-M
NOTE: Native VLAN 1 doesn't appear to have this issue. All devices state that they are the root bridge for VLAN 100 and 200.
I do not see the config consistency in all switches:
1. I do not see any VTP config, which can replicate the VLAN config to other switches :
2. All the switches connecting each other port should be a trunk to pass the VLAN information.
I have provided the solution to work, but I would suggest learning so you understand better and fix the issue, so you know the mistakes.
The below document explain you
https://www.ciscopress.com/articles/article.asp?p=2181837&seqNum=8
https://networklessons.com/switching/cisco-dtp-dynamic-trunking-protocol-negotiation
happy labbing !!
BB
I configured VTP domain, password, and version on all switches. If I hadn't, then how would the VLANs have propagated to the other switches. I only configured VLANs on DLS1. It seems like I am possibly running into a glitch.
etodust
Frequent Visitor
Frequent Visitor
I've redone this lab over and over, with the same result. All switches consider themselves the root bridge for VLANs 100, and 200. VLAN 1 behaves normally in regards to STP.
Note: balaji.bandi was wrong about me not having VTP configured. VTP configurations are not shown in the running-config.
etodust
Frequent Visitor
Frequent Visitor
Never give up!
