External Connectivity Issue // CML Node Unable to Ping Gateway
ShaneFroebel
Dear Fellow Cisco CML Users & Cisco -
I usually I am able to solve these issues, but I am at a lost and need help. I have setup Cisco CMLv2 inside my ESXi Enviroment. It has two NICs:
* Web and Management - VLAN Y
* CML Node External Network - VLAN 523
On the ESXi side the VLAN is tagged and the links through he Cisco UCS/FI down to the Nexus 7k are trunk to the port from the FI.
As you can see the "VLAN" is in the allowed state and below.. is the SVI;
HSRP is running and this SVI is currently ".1".
So that's good. I do see my nodes in CML getting the DHCP address from the DHCP servers,
However, the node (NX-9000v) can not ping the GW, but the normal .3 address of this particular switch.
Arp Table:
BHDATANEXUS02-AGR# show mac address-table vlan 232
Note: MAC table entries displayed are getting read from software.
Use the 'hardware-age' keyword to get information related to 'Age'
Legend:
* - primary entry, G - Gateway MAC, (R) - Routed MAC, O - Overlay MAC
age - seconds since last seen,+ - primary entry using vPC Peer-Link, E - EVPN entry
(T) - True, (F) - False , ~~~ - use 'hardware-age' keyword to retrieve age info
VLAN/BD MAC Address Type age Secure NTFY Ports/SWID.SSID.LID
G 232 0000.0c9f.f0e8 static - F F sup-eth1(R)
G 232 002a.6aa4.f243 static - F F vPC Peer-Link(R)
G 232 002a.6aa5.1042 static - F F sup-eth1(R)
* 232 0050.56a3.88c7 dynamic ~~~ F F Eth1/48
* 232 5254.0008.1d8d dynamic ~~~ F F Eth1/48
* 232 5254.000a.32f9 dynamic ~~~ F F Eth1/48
BHDATANEXUS02-AGR#
Shane
0 Replies 0
