How do i fix 502 bad gateway
pgaltieri
I had CML running fine.  I had configured 2 interfaces on the CML VM, one bridged and one NAT.  The address that got assigned to the CML was from the NAT interface.  I turned off this interface and rebooted so the CML would get it's address from the bridged network.  This all worked, the CML UI is at 192.168.10.80 rather than at 172.16.192.128.  However, when I try to connect to this address I get the login screen, but when I login I get a 502 Bad Gateway error.  If I connect to 192.168.10.80:9090 I have no problems.  How do I get rid of the 502 Bad Gateway error?
Paolo
10 Replies 10
balaji.bandi
I tried both methods and I still get the 502 Bad Gateway error. I even
tried removing bridge1 and going the steps of configuring it again.  All
to no avail.  No matter what I try I continue to get 502 Bad Gateway.
Paolo
Hi Paolo,
Just checking that you have not tried to update the the system using cockpit, as this is how I messed up my setup and had to create the VM from scratch and reach out to Sales to get my activation cleared.
If you have managed to crash the CML if other way, have a look that you have all services running in cockpit.
Thanks for the info.  I did in fact update my system yesterday which is
when this problem started.  I updated another system running CML and the
same happened, and when I re-created the VM it locked up with an out of
compliance issue.  So I suspect the same thing will happen when I
re-create the VM here.
Paolo
Stefano Pilla
Hi @pgaltieri ,
do you have the virl2-controller.service started (Cockpit > Services > System Service)? Has this happened after the upgrade?
I have the same issue and I have the virl2-controller.service that is getting stopped with "virl2-controller.service: Failed with result 'signal'."
Thank you
Stefano,
  I believe the update to CentOS is what caused the problem.  The only
way I managed to fix it, sort of :(, was to create a new VM. The problem
now is when I try to register the new VM I get an "Out of Compliance"
error.  So I have to fix this error :(
Paolo
One way to eliminate the problem is to do the following on the CML VM
sudo systemctl restart virl2.target
This eliminated the 502 error for me and allowed me to de-register the license and re-deploy.
Paolo
Stefano,
  I believe I have found a fix to the 502 bad gateway problem.  When it occurs login to the CML OVA and issue the following:
This fixed the problem for me on 2 systems.  Including one where I had sent Karlo a request to fix it.  I have sent him email with the same information.
Paolo
sstotko
Hi, same problem here.
After updating CentOS via the CML Admin-GUI the CML service wouldn't start anymore.
In total there are three services that don't run porperly anymore:
systemd-timedated.service
timedatex.service
With the last two only one will run while the other complains that there is already a service running with the same BusName.
From what I can tell, the virl2-controller.service requires both to be up to run and it is virl2-controller.service that runs the socket which nginx is trying to open (and throwing a 502 bad gateway).
It's too bad the licensing is stuck in the now inaccessible Lab-GUI rather than in the Admin-GUI, this way we can't just set up a new VM.
Hope someone finds a solution to this.
Cheers,
Stephan
there are multiple threads going on for this issue and there's still no "official" solution.
I had to re-deploy my CML as the update broke the system. I have put some more details here on my conclusions: https://learningnetwork.cisco.com/s/question/0D53i00000XSv2RCAT/virl2controllerservice-failed-with-result-signal-what-is-the-fix-for-this-i-tried-restarting-the-service-in-the-sysadmin-account
At the moment the only solution seems to be to re-deploy and have the license release by the Store Team emailing Karlo (kabobile@cisco.com) please see the Out of Compliance instructions here: https://learningnetwork.cisco.com/s/question/0D53i00000VCdNGCA1/out-of-compliance-issuefix
On the new instance do not upgrade unless instructed to do so on the Cisco Documentation.
Thank you
