Layer 3 switching and IP routing
Frank57510
Hi folks,
I've got a quick question concerning layer 3 switching and specifically the command 'ip routing'.
This command normally would enable the ip routing protocol on a switch, basically turning a layer 2 switch into a layer 3 switch, right? But as far as I know, you should be able to see the 'ip routing' entry in the config or am I wrong? I'm a little confused wether I turned it on or not.
A little context, I was doing a lab with some VLANs and some SVI's and doing a couple of pings from a computer on 1 VLAN to a computer on another VLAN, which worked just fine. But I didn't use the 'ip routing' command prior to those pings, so I'd expect the pings to fail which they didn't.
Do the IOSvL2 switches you deploy in CML have ip routing turned on by default or am I missing something?
Hope anybody could help me clear this up.
Thanks!
balaji.bandi
some time if the IOS default ip routing enable you won't be able to see with show run
try the below command :
#show run all | in routing
BB
balaji.bandi
BB
You sir, are a lifesaver!
It was driving me nuts and I couldn't wrap my head around it.
Using that command did in fact show the ip routing entry in the running config and I was finally able to confirm it was enabled.
Thanks!
