NXOS boots up in loader mode using CML 2.7.1
derek.owens
Greetings,
Trying to create a lab environment where I'm using (7) NXOS9K's in SPine/Leaf mode configuration.  I ahve the proper memory, CPU & Disk space but when I try to start (1) node at a time it comes up in loader mode:
dsDxe: loading Boot0001 "UEFI QEMU HARDDISK QM00005 " from PciRoot(0x0)/Pci(0x8,0x0)/Sata(0x0,0xFFFF,0x0)
BdsDxe: starting Boot0001 "UEFI QEMU HARDDISK QM00005 " from PciRoot(0x0)/Pci(0x8,0x0)/Sata(0x0,0xFFFF,0x0)
Sysconf checksum failed. Using default values
WARNING: No BIOS Info found
ATE0Q1&D2&C1S0=1
Standalone chassis
check_bootmode: grub2pxe: grub failed, launch ipxe
Trying to load ipxe
Loading Application:
/Vendor(429bdb26-48a6-47bd-664c-801204061400)/UnknownMedia(6)/EndEntire
BdsDxe: loading Boot0001 "UEFI QEMU HARDDISK QM00005 " from PciRoot(0x0)/Pci(0x8,0x0)/Sata(0x0,0xFFFF,0x0)
ATE0Q1&D2&C1S0=1
Standalone chassis
Trying to load ipxe
ATE0Q1&D2&C1S0=1
Standalone chassis
Trying to load ipxe
ATE0Q1&D2&C1S0=1
Standalone chassis
Trying to load ipxe
ATE0Q1&D2&C1S0=1
Standalone chassis
Trying to load ipxe
ATE0Q1&D2&C1S0=1
Standalone chassis
Trying to load ipxe
ATE0Q1&D2&C1S0=1
Standalone chassis
Trying to load ipxe
ATE0Q1&D2&C1S0=1
Standalone chassis
Trying to load ipxe
ATE0Q1&D2&C1S0=1
Standalone chassis
Trying to load ipxe
cannot load imageFailed to launch ipxe
Came back to grub, now load efi shell
Trying to load efishell
cannot load imageFailed to launch shell
Trying to read config file /boot/grub/menu.lst.local from (hd0,4)
Filesystem type is ext2fs, partition type 0x83
Trying to read config file /boot/grub/menu.lst.local from (hd0,5)
No autoboot or failed autoboot. falling to loader
Loader Version 5.9.3.94
loader >
Anybody have any suggestions as to how to bring this up?  When I look at the DIR I see => nxos64-cs.10.4.2.F.bin I try to boot from that image but still get the same error msg.  Any help would be greatly appreciated.
derek.owens
Found the issue: Go to DIR & type in boot & name of the nxos file in directory; once systems is booted you type the following:
boot nxos bootflash:<file_name> which is the path to the boot image
then type: copy running-config startup-config
balaji.bandi
If you do not like to boot next time boot loader
better setup and boot variable and save the config
example :
switch# configure terminal
switch(config)# boot kickstart bootflash:kickstart-image
my Lab i did this :
switch# conf t
Enter configuration commands, one per line. End with CNTL/Z.
switch(config)# boot nxos bootflash:nxos.x.x.x.bin
end
copy run start
BB
