Supplemental ISO SD-WAN Images - Cisco Modelling Labs
Does anyone know why you wouldn't be allowed to download the Supplemental ISO image to add SD-WAN nodes to CML?
Message recieved says service contract required when the download button is clicked even though the 40 node deployment option for CML has been purchased.
rkochery
Hi @00u1cnw4sxi7u9iQl5d7 , Download pages/entitlements are different for CML Enterprise and Personal. If you purchased personal, you should click on the Download button in your CLN Store my account page. It will take you here https://software.cisco.com/download/home/286290254/type/286290305/release/CML-Personal%202.7.2
From the FAQ, it implies that CML grants you the entitlement, while previous methods did not...
 SD-WAN Support and Images
With the release of CML 2.7.0, CML will provide Catalyst SD-WAN images to our customers on a new ISO image of supplemental VM images. While previous versions of CML could run the Catalyst SD-WAN images, a CML license did not provide access to those VM images. Therefore, only customers who had access to the SD-WAN images via some other entitlement could download them and add them to CML.
https://developer.cisco.com/docs/modeling-labs/#!cml-release-notes/summary-of-changes
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Thank you for the reply.
I thought this was the case, CML has already been purchased and yet it doesn't seem to automatically recognise the entitlement when downloading from - https://software.cisco.com/download/home/286193282/type/286326381/release/2.7.2
Am I miss understanding something ?
Accessing SD WAN controllers vManage via GUI in CML 2.8 issue
I had installed refplat_p-20240322-supplemental-iso in cml 2.8, and can access all controllers and V edges images only+external connector in this package, after that initial configuration applied on the contorllers vmanage, vbond,vsmart, I need to access vManage on GUI/webrowser to onboard the vedge nodes on it,  I did not find any host/server in this package, where can connect to the external host-window serer etc for GUI access. How can I connect and access vmanage on GUI in this scernario? Thank you
I am using VMware workstation 17 player for cml virtual environment.
Looking forward to it and I really appreciate your help and guidance please.
rkochery
