3rd party SX10 Peripherals disconnect after a while
JonasLejon
Hi all,
I have an issues that Cisco cant provide the answer to.
The problem is that i have several systems with 3rd party control system (crestron) and on SX20 it is stay connected but on the SX10 the codec stop sending responce.
The solution is:
Crestron processor connected via Telnet to SX10 or SX20
The processor comunicate via Telnet and register Peripherals with the
"xcommand peripherals connect Type:"touchpanel" Name:"TCCC4 Verion 4.5" ID:"00:10:7f:6d:39:da" NetworkAddress:"10.192.193.53" this is sent every 6000ms to the codec
At some point the SX10 is connected but not sending responce back.
SX20 there is no issues its always receiving a responce
  • Software verison is the same CE9.14
  • config is the same
  • No network issues between the processor and codec
  • Same processor is connected to SX10 and SX20 and the result is the same SX20 no problem, SX10 working a day and then no RX data received from codec
SX10 after a day
TXData 0124: "xcommand peripherals connect Type:"touchpanel" Name:"TCCC4 Verion 4.5" ID:"00:10:7f:6d:39:da" NetworkAddress:"10.192.193.53""
TXData 0023: "xfeedback deregisterall"
TXData 0030: "xfeedback register status/call"
TXData 0036: "xfeedback register status/conference"
TXData 0031: "xfeedback register status/audio"
TXData 0053: "xfeedback register status/video/input/mainvideosource"
TXData 0038: "xfeedback register status/video/layout"
TXData 0040: "xfeedback register status/video/selfview"
TXData 0033: "xfeedback register status/standby"
TXData 0024: "xfeedback register event"
TXData 0027: "xpreferences outputmode xml"
SX10 Before its stopped
RXData 0076: "
<XmlDoc resultId="">
<PeripheralsConnectResult status="OK"/>
</XmlDoc>
RXData 0076: "
</XmlDoc>
RXData 0076: "
</XmlDoc>
Anyone that has been experience this issues?
Best regards
Jonas Lejon
mneergaa
As far as I can tell, this question is completely unrelated to the Cisco Proximity app...
bolam
If you are using USB to Serial between Crestron and SX20 please noted that following bug may effected(event it was CE version - Cisco TAC said BU didn't fix the issues from TC 7.3.x No release planned to fix this bug
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvb38947/?rfs=iqvred
(I am asking local team to check about that hope they will fix it since the bug was discovered before the SX20 SW EOL)
