Cisco Proximity 2.0.8.0 Uninstall Problem
HKO
The Proximity v2.0.8.0 uninstaller deletes the files but leaves behind the uninstaller registry entries. Running it a second time removes them. This is causing problems with unattended SCCM packages.
mneergaa
That's not good. Sadly, noone on our team have extensive experiense with Windows / MSI / SCCM. If you could point us to which registry entries are left behind, that would be great. Any other information you have, including whether you are deploying per-user pr per-system, would also be appreciated =)
I found that the uninstall option for 2.0.8.0 is not available on Win 7 and Wind 10. is there any way i can uninstall program, because i would like to deploy Webex Meeting desktop app.
I don't understand why you wouldn't be able to uninstall it. Have you tried upgrading to the latest version first?
