3985
How to make Proximity work? Help needed
Dear Proximity team,
I recently installed Proximity version 1.1.1.0 Windows. Since installation completed, the Proximity tray icon keeps saying "Searching for video systems..." when I mouse over it.
I tried to sit close to TP device (building 31 1st floor Hearts Castle conf room), and there is nothing happens. What should I do to make this work?
My laptop is Lenovo W540, a standard Cisco laptop. I see my colleague who has Macbook has using Proximity to share screen, and it is pretty nice feature but my windows version just does not work for me.
Please help and appreciated.
Sam
Some update: by reading the reply to others, I disabled all the effect with my mic, then proximity starts working.
Everyone's tags (1)
1 ACCEPTED SOLUTION
VIP Advisor
Hi Marc,
Hi Marc,
It's highly recommended that you upgrade your SX10 to CE8.x which fully supports Proximity.
TC7.3.2 is also subject to some security vulnerabilities, and this version has been deferred as well.  If you're going to stay on the TC software train, you should upgrade to at least version TC7.3.6.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
18 REPLIES 18
Please check the following:
1. Is your microphone muted?
2. Is your microphone volume low?
3. Disable any audio enhancments in the microphone settings.
Dan
Enthusiast
I also fiddled with this for
I also fiddled with this for a long time on several windows laptops... it ended up just making me mad. Not a fan of Proximity. The idea seems cool, but Cisco is way over thinking this one. There needs to be an option to simply put in the IP address or hostname of the telepresence unit if this problem occurs...
Beginner
Same here... tried for 30+
Same here... tried for 30+ minutes making changes as suggested in various combinations, and still my laptop (Lenovo X230) cannot be detected.  Perhaps ultrasound is not such a good idea especially now Cisco is allowing pet dogs to join us in the office :-)
Highlighted
Beginner
It did work for me by waiting
It did work for me by waiting almost 3 minutes for my laptop to find Proximity... Used it in a couple of different rooms with success
What is microphone boost and
What is microphone boost and microphone level set to?
Beginner
Microphone level is 96 with
Microphone level is 96 with 10dB boost... see attached for enhancement settings
Please tick "Disable all
Please tick "Disable all sound effects". This has a high change of fixing the issue.
We are working to solve this issue in a different matter. Stay tuned.
Disabling Mic sound effects
Disabling Mic sound effects finally solved the issue with Proximity searching constantly...But refresh rate is quite bad :-(
What number of frames pr
What number of frames pr second are you experiencing? Around 3 fps is what you can expect with a good network.
Also, please review this
Also, please review this document:
 https://supportforums.cisco.com/sites/default/files/proximity_for_windows_in_beta.pdf
hi,
hi,
I'm working with a Lenovo W530, with the same effect. Proximity is still searching for video systems. Mic is working well, not muted.
Is it a problem with the mic and higher frequencies and driver? Does anyone has a Lenovo 530 (win7 cisco IT Installation, proximity 1.1.1) working well with proximity?
Thanks in advance
Günter
Hi Guenter,
Hi Guenter,
Please upgrade to the internal alpha version and you will hopefully have more luck.
Dan
Thank you Dan for quick reply
Thank you Dan for quick reply. Where can i get the internal alpha?
Günter,you find internal
Günter,
you find internal versions on http://alto.cisco.com (from the Cisco network).
Best regards,
Henrik
Content for Community-Ad
July's Community Spotlight Awards
