11-12-2018 04:53 AM
11-12-2018 05:47 AM
I can give you the most likely hypothesis:
You can try disabling audio enhancements if you wish to be able to record while the application is in the background.
11-12-2018 11:34 PM
Thank you very much! It worked with disabling sound effects.
Do you know if this is solved in Proximity where it could also connect in background but without a need of disabling sound effects?
11-12-2018 11:34 PM
Forgot to mention that it is 3.0 version where this might be fixed?
