01-02-2017 09:21 PM
Would like to know what third party speakers people have used with success connected to the SX80 using Intelligent proximity.
Solved! Go to Solution.
01-03-2017 02:16 AM
Hi allanwells99,
I would say that 90+ % of all speakers would give reliable pairing, but we do not maintain a list of approved or tested devices.
So far, we have only seen issues with a few setups, among them some "sound bars" (typically used to improve TV sound) that distort the pairing signal due to heavy signal processing. I've had feedback from customers that stick this into existing PA systems in auditoriums etc and get reliable pairing.
Also - even though the "Frequency response" on a spec sheet might say eg. 40 Hz - 20 kHz, there is usually still some volume above 20 kHz, enough to provide decent pairing.
Some "anecdotal evidence"
01-23-2017 04:06 AM
Hi Alan,
unfortunately this is not "binary science"; regardless of choice of speakers, it is impossible to guarantee pairing 100% of the time. The pairing requires a good signal (speakers ability to reproduce the token), acoustic conditions (room treatment, absorption etc) and microphone pickup (microphone in the device you want to pair).
The best advice is to control as much of this as possible; eg by using Cisco speakers in fully integrated systems, or well-tested speakers for the integrator systems. But almost as important is the acoustics in the room—here I really recommend the "Room Acoustics" chapter in the "Project Workplace: Best practice" guide available from https://www.cisco.com/web/telepresence/collateral/pr.pdf
And as stated before; most speakers will work, none can be said "works 100%", so your mileage may vary.
All that said (my main point being that specific speaker models might not help you much); I have had good experience with the already mentioned Logitech X-140 (on my desk), and a couple of Genelec 8050A speakers in a larger all-hands area.
Best regards,
Henrik
01-03-2017 02:16 AM
Hi allanwells99,
01-03-2017 09:10 PM
Thanks Henrik,
Appreciate you taking your time to provide feedback.
The main concern is the failing to pair aspect or intermittent failure to pair ( will ruin the user experience completely). So Ideally when deploying SX80 and 20 we would have a reference to speakers that will work 100%. It just makes it difficult / time consuming at present to complete design not knowing or having completed tests or real functional working deployments like you have/may have done :)
What were the models that worked well?
Thanks again
Allan
01-23-2017 04:06 AM
Hi Alan,
Best regards,
Henrik
