ASR 1001 Crash -After Firmware Upgrade
Sandy!
Upgraded the firmware for ASR 1001 x from 15.2 to 16.4 and also upgraded the Rommon.
After the reload, the router didn't come up.
After 30 minutes, Completely turned off the router and then started it.
still the router didn't start, tried to connect through the console cable using ssh but couldn't connect.
what are the steps that i need to do to make the router up and running.
I have backed the config!
Best Regards,
Sandy!
Sandy!
Hello All,
I booted with a different image, after the reboot the router couldn't find the image and deleted all the table contents.
Because of this the old image on the flash also was deleted.
I rebooted with a new image with USB physically and everything resolved.
Thanks for all your help.
Cheers,
Sandy!
9 Replies 9
johnd2310
Level 8
Level 8
What is the output of the Console when you restart the router?
John
**Please rate posts you find helpful**
rommon 2 > showmon
Current image running (0/1): Boot ROM1
System Bootstrap, Version 15.2(1r)S, RELEASE SOFTWARE
Copyright (c) 1994-2011 by cisco Systems, Inc.
rommon 3 > sysret
System Return Info:
count: 0,  reason: reset
pc:0x0,  error address: 0x0
Stack Trace:
FP: 0x00000000, PC: 0x00000000
rommon 4 > reset
Resetting .......
Initializing Hardware ...
Calculating the ROMMON CRC ... CRC is correct
Current image running: Boot ROM1
Last reset cause: Watchdog/ICH
ASR1000-1RU platform with 4194304 Kbytes of main memory
Directory asr1001x-universalk9.16.06.04.SPA.bin not found
Unable to locate asr1001x-universalk9.16.06.04.SPA.bin directory
Unable to load asr1001x-universalk9.16.06.04.SPA.bin
boot: error executing "boot bootflash:/asr1001x-universalk9.16.06.04.SPA.bin"
autoboot: boot failed, restarting...
no valid BOOT image found
Final autoboot attempt from default boot device...
boot: cannot determine first file name on device "bootflash:/"
rommon 1 >
Post the complete output to the command "dir bootflash:".
Leo Laohoo
Console into the router and reboot.
Post the entire bootup process so we can determine what is going on.
Hello Leo,
We have a server that has the Com connection to the router!
I remoted into the server and ssh into the router using putty!
After clicking the open in putty , nothing happened ! no error messages pops up!
Now how can i connect to the router , or does turning on and off the router will reboot the router?
Best Regrads,
Sandy!
rommon 2 > showmon
rommon 3 > sysret
System Return Info:
Stack Trace:
rommon 4 > reset
Resetting .......
rommon 1 >
I believe that you do not meet the minimum ROMMON requirement. You are showing 15.2.1r.s and I believe you need at least 15.4.2r.s
Sandy!
Hello All,
Cheers,
Sandy!
Sandy!
Hello All,
Cheers,
Sandy!
