06-02-2025 08:28 PM
I am currently working on a school project with the requirements of
Your restaurant network will use IPv4 address ranges 10.10.1.0 to 10.10.1.255 (255.255.255.0)
while your web server connected to your restaurant router will use 10.10.2.100 (255.255.255.0).
All devices should be able to ping each other when it is configured and connected correctly.
There should be no need to do any IP address subnetting.
You should setup a HTTP web server in your restaurant network connected directly to your setup
router where your restaurant end device can see the webpage that has been setup (to simulate
the ordering platform). Use the Cisco Packet Tracer Simulation Mode for this assignment with
appropriate screenshots of the TCP/IP layers and explanations to illustrate the encapsulation and
de-encapsulation process for sending and receiving in order for your end device to access and see
the webpage when the user keys in http://10.10.2.100  in the browser URL.
I am not sure why the simulation mode came up errors and packet lost, while trying to visit the url it timed out
Solved! Go to Solution.
06-02-2025 10:55 PM
@YL3 hi, change your default gateway in server to 10.10.2.1.
06-05-2025 03:31 AM
You know this is very important that you connect the both networks through gateway (router). It is easy for small and static networks but for the scalability you need to have routing protocol configured in the router that have the dynamic updates from both subnets
Now what are the advantages and disadvantages of both scenarios i.e. 1. Network with just Gateway (router) OR 2. Network with routing protocol configured on router (eg. RIP, OSPF, BGP)
Static Routing (Router as Gateway)
How it works:
MAC Table Behavior:
ARP Table Behavior:
Summary:
| Table | Where it Exists | Contents |
| MAC Table | Switch | MAC of local hosts + MAC of router interfaces |
| ARP Table | Host + Router | Host: router’s IP → MAC; Router: IP-MAC for connected hosts |
Scenario 2: Dynamic Routing (Routing Protocol used)
How it works:
MAC Table Behavior:
ARP Table Behavior:
Important Point:
| MAC Table | Switch | No change — local MACs + router MAC |
| ARP Table | Host + Router | Hosts: gateway MAC; Router: ARP for connected next-hops |
06-02-2025 10:55 PM
06-02-2025 11:09 PM
@Kasun Bandara that solved the ping and url issue, but there still is errors in simulation
1. The ICMP process replies to the Echo Request by setting ICMP type to Echo Reply.
2. The ICMP process sends an Echo Reply.
3. The device encapsulates the data into an IP packet.
4. The device looks up the destination IP address in the CEF table.
5. The CEF table does not have an entry for the destination IP address.
6. The device looks up the destination IP address in the routing table.
7. The routing table does not have a route to the destination IP address. The device drops the packet
Last device:Switch0 At device: Wireless Router0
1. The frame's destination MAC address matches the receiving port's MAC address, the broadcast address, or a multicast address.
2. The device does not have a service that accepts this frame. It drops the frame.
Last device:Switch0 At device: Router0 and Last device:Switch0 At device: PC0
Is it possible to solve this? Thanks in advance.
06-04-2025 01:10 AM
Is this problem resolve or still pending
pl reply
06-04-2025 01:23 AM
Hi, sorry for the late reply the previous mentioned problems are still pending.
06-04-2025 10:24 PM
Sorry my previous question is dumb, ive changed the simulation mode now using only ARP, HTTP and ICMP. The problem is face is when i try pinging other device are,
2. The device decapsulates the PDU from the Ethernet frame.
3. The frame is an ARP frame. The ARP process processes it.
4. The ARP frame is a request.
5. The ARP request's target IP address does not match the receiving port's IP address.
6. The ARP process drops the frame.
Thanks in advance.
06-05-2025 03:05 AM
I have downloaded you network topology designed in packet tracer.  currently you are not using any routing protocol but both networks 10.10.1.x and 10.10.2.x connects each other through gateway (router).
Pl reply that what exactly you need to do because I didn't understand you point.  Do you want to check the communication through Simulation Mode in which you need ARP, ICMP and HTTP protocols working OR you want to check the mac address table, OR arp table or anything else.
Pl clarify your target and what command you are using currently.
06-05-2025 03:31 AM
How it works:
MAC Table Behavior:
ARP Table Behavior:
Summary:
How it works:
MAC Table Behavior:
ARP Table Behavior:
Important Point:
06-05-2025 03:37 AM
Final Comparison (MAC/ARP Focused)
Feature Scenario 1 (Static Routing) Scenario 2 (Dynamic Routing)
MAC Table on Switch Learns host & router MACs Same
ARP Table on Hosts Contains only gateway (router) MAC Same
ARP Table on Router For directly connected hosts only Same; plus next-hop resolution via ARP
MAC/ARP Dependency on
Routing Protocol
06-05-2025 03:38 AM
do let me know if its helpful
06-05-2025 03:42 AM
I have fixed it thx for the help.
