Need Help Fine-Tuning an EEM Script that Resets T-1 PRI Interface
Paul Wishart
We currently use the following script to reset the PRI when it fails. This works fine, but sometimes generate dozens of alerts when the link is flapping. I am trying to build a script that won't generate more than one email every five minutes. Here is the current working script: event manager applet serial_interface_reset authorization bypass event syslog pattern "%ISDN-6-LAYER2DOWN:" maxrun 180 trigger delay 25 action 1.0 cli command "enable" action 2.0 cli command "config t" action 3.0 cli command "int Serial0/1/1:23" action 3.1 cli command "shutdown" action 3.2 wait 10 action 3.3 cli command "controller T1 0/1/1" action 3.4 cli command "shutdown" action 4.0 wait 10 action 4.1 cli command "no shutdown" action 4.2 cli command "int Serial0/1/1:23" action 5.0 wait 10 action 5.1 cli command "no shutdown" action 5.2 wait 10 action 5.3 cli command "no network-clock synchronization automatic" action 5.4 cli command "network-clock synchronization automatic" action 6.0 cli command "end" action 7.0 mail server "$_email_server" to "$_email_to" from "$_email_from" subject "Site on Router Name ISDN-6-LAYER2DOWN:" body "PRI Failure Detected and Reset - call Site and if unreachable, open a HIGH priority ticket with the network team!" action 8.0 syslog msg "ISDN-6-LAYER2DOWN - EMail Sent to VTOC Group" Here is what I have tested, but can't get it to work:
event manager applet serial_interface_reset authorization bypass event syslog pattern "%ISDN-6-LAYER2DOWN:" maxrun 180 trigger delay 25 action 0.1 cli command "dir bootflash:layer2down.flag" action 0.2 regexp "No such file" "$_cli_result" _no_file action 0.3 if $_no_file eq 1 action 1.0 cli command "enable" action 2.0 cli command "config t" action 3.0 cli command "int Serial0/1/1:23" action 3.1 cli command "shutdown" action 3.2 wait 10 action 3.3 cli command "controller T1 0/1/1" action 3.4 cli command "shutdown" action 4.0 wait 10 action 4.1 cli command "no shutdown" action 4.2 cli command "int Serial0/1/1:23" action 4.3 cli command "no shutdown" action 5.0 wait 10 action 5.2 cli command "no network-clock synchronization automatic" action 5.3 cli command "network-clock synchronization automatic" action 6.0 cli command "end" action 7.0 mail server "$_email_server" to "$_email_to" from "$_email_from" subject "Site on Router Name ISDN-6-LAYER2DOWN:" body "PRI Failure Detected and Reset - call Site and if unreachable, open a HIGH priority ticket with the network team!" action 8.0 syslog msg "ISDN-6-LAYER2DOWN - Email Sent to VTOC Group" ! Create a flag file by appending to an existing one or creating new action 9.0 cli command "copy null: flash:layer2down.flag" action 9.1 end event manager applet reset_email_flag event timer watchdog time 300 action 1.0 cli command "delete /force flash:layer2down.flag"
balaji.bandi
Just to understand the Script working, but you getting too many emails and you like to cut-down sending email every 5min ?
BB
Paul Wishart
Yes, that's correct.
