Software difference Catalyst 4500 update help
kevinscottdignum
Frequent Visitor
Frequent Visitor
I have multiple Catalyst 4500s running cat4500e-universalk9.SPA.03.11.00.E.152-7.E.bin  The recommended versions are either 16.6 or 16.9  That seems like a huge jump......  What is the difference in these releases?  Is it a license/feature connected thing?
 Can I jump from 3.11 to 16.6?
I have not found a document that I understand that tells what is what between 3 and 16.
Ok, so this is a 4500X (similar to Sup7).
4500X do not support IOS-XE "16.X.X". Last final support is 3.11.X.
5 Replies 5
balaji.bandi
 What is the difference in these releases ?
difference you can read release notes, most of the 5 Star rated one is good for production deployment, untiul you have any major bug and cisco fixed it upgrade to mainenance release.
You can jump from  3.X  to 16.X , as per my understand Cisco sto developping denali code that is 3.X
they are more focussing on 16.X Code for the further stable and furture releases.
When you upgrading from 3.x to 16.X read the release notes, it may require firmware upgrade.
https://www.cisco.com/c/en/us/support/ios-nx-os-software/ios-xe-16/products-release-notes-list.html
BB
Leo Laohoo
Can you post the complete output to the command "sh version"?
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.11.00.E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Sat 23-Mar-19 13:45 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG12
PAI-85151-MDF-4500X-16P uptime is 1 day, 7 hours, 39 minutes
System returned to ROM by reload
System restarted at 07:47:59 AZ Sun Mar 29 2020
System image file is "bootflash:cat4500e-universalk9.SPA.03.11.00.E.152-7.E.bin"
Jawa Revision 3, Winter Revision 0x0.0x41
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
License Information for 'WS-C4500X-16'
License Level: entservices Type: Permanent
Next reboot license Level: entservices
cisco WS-C4500X-16 (MPC8572) processor (revision 9) with 4194304K bytes of physical memory.
Processor board ID JAE203500AB
MPC8572 CPU at 1.5GHz, Cisco Catalyst 4500X
Last reset from Reload
4 Virtual Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
@Leo Laohoo  make sense due to old hardware.
BB
