Supported platforms for Cisco Modeling Lab
C. Rod Weir
Can CML be deployed on a Linux or Windows workstation or does it just matter what version of VMware you have?
Martin L
Either Linux or MAC OS or Windows OS will do just fine; VMWare workstation 15 or 16 or VMware ESXi or VMware Player may work as well. Note: people using Linux may need to have Linux OS experience due to some small OS config issues .
see Install Guide from https://developer.cisco.com/docs/modeling-labs/#!system-requirements
Regards, ML
**Please Rate All Helpful Responses **
Martin L
Regards, ML
balaji.bandi
Look at the FAQ : (bare metal and VM supported - esxi i have tested 6.5 and 6.7 works - vmware workstation 12)
https://developer.cisco.com/docs/modeling-labs/#!faq/faq---cisco-modeling-labs-v2x
BB
