CISCO 891 with SFP.... read out light level on Gi8 WAN Port ???
knu_ger
Hi all,
how to read the level of a ciaco 891at the Wanport.SFP out ???
router#sh int gigabitEthernet 8
GigabitEthernet8 is up, line protocol is up
  Hardware is PQ3_TSEC, address is XXX)
   MTU 1500 bytes, BW 1024 Kbit/sec, DLY 10 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is LX
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 2w2d
Thanks to all of you for your help!
Seb Rupik
HI there,
I don't have a 891 to test on, but the following command might work:
sh int gi8 trans det
cheers,
Seb.
Hi Seb Rupik ,
sorry but ..Cisco 891 does not know this command look ....
Router_1#sh interfaces gigabitEthernet 8 ?
  accounting      Show interface accounting
  counters        Show interface counters
  crb             Show interface routing/bridging info
  dampening       Show interface dampening info
  description     Show interface description
  history         Show interface history
  human-readable  show interfaces output with larger numbers separated by comma(s)
  irb             Show interface routing/bridging info
  mac-accounting  Show interface MAC accounting info
  mpls-exp        Show interface MPLS experimental accounting info
  precedence      Show interface precedence accounting info
  pruning         Show interface trunk VTP pruning information
  rate-limit      Show interface rate-limit info
  stats           Show interface packets & octets, in & out, by switching path
  summary         Show interface summary
  switching       Show interface switching
  switchport      Show interface switchport information
  trunk           Show interface trunk information
  users           Show interface users
  |               Output modifiers
hmmmm maybe the 891 doesn't support DOM. As a last ditch effort, see if the following config works:
transceiver type all
  monitoring
Then see if the following command is accepted:
show interface transceiver
cheers,
Seb.
The command "Transceiver "is not supported .
i still have the problem .
it must be possible to read the values !
with a 4300 it goes ....
Router #sh hw-module subslot 0/0 transceiver 0 status   (GigabitEthernet0/0/0)
The Transceiver in slot 0 subslot 0 port 0 is enabled.
  Module temperature                        = +49.273 C
  Transceiver Tx supply voltage             = 3198.0 mVolts
  Transceiver Tx bias current               = 22550 uAmps
  Transceiver Tx power                      = -5.6 dBm
  Transceiver Rx optical power              = -7.2 dBm
Router #
