ISR4321 Console Port
Pixels IoT
how can i configure ISR4321 Router with USB to RJ45 console cable. cant see any RJ45 Console port at back of the router.
Leo Laohoo
Possibly a counterfeit.
ISR4321 router have two (2) Console ports:
  1. RJ-45
  2. USB Type B mini port
See PICTURE.
balaji.bandi
Maybe do not confuse with @Leo Laohoo comment with numbers 1 and 2 - that is option (in the picture  port reference numbers are different- hope you not)
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/hardware/installation/guide4400-4300/C4400_isr/Overview.html
BB
NetworkDave
@Pixels IoT,
The Cisco datasheet states that the 4321 ISR provides these console ports and Auxiliary port:
<Output Omitted>
• One USB mini-Type B console (placed next to the RJ-45 console port)
• One RJ-45 console port
• One RJ-45 auxiliary port
<Output Omitted>
Provided is an image showing a console cable plugged into the RJ45 console port. Viewing from the back, It is to the right of the USB mini-Type B console port and underneath the RJ-45 AUXiliary port.
I agree that it is not clearly marked...it can easily be mistaken as a second RJ-45 auxiliary port.
Remember to mark helpful posts and mark the correct answer as a solution; It helps other users with similar questions.
