Dealing with Basic Authentication & Bearer tokens in Cisco-Workflows
HannesHeinrich
Hello everyone,
I noticed the following problem today when trying out Cisco Workflows.
A token must be created for authorisation on the Umbrella API (Create Authorization Token - Cloud Security API - Cisco DevNet). I have created the Umbrella API as a ‘HTTP Endpoint target’  in workflows for this purpose.
Since I don't want to generate the token again and again via a manual script after the 3600-minute expiry time, I created the ‘target’ with the basic authentication (which doesn't change that often).
I then built a task that queries the bearer token:
The whole thing also works, I get a valid token back, which I have also tested via Postman.
As soon as I now want to query all tunnels from my umbrella organisation in my next task, e.g. via API, I get a problem.
I have to use my ‘api.umbrella.com’ as the target again, which still uses Basic authentication (In the URL field I have the following limitation ‘Relative URL for System APIs, Device Registration and Target APIs. Does not support specifying fully qualified URL.").
Now I have simply written the Barer token in the header, in the hope that this will overwrite the Basic Auth:
(not the real token)
Unfortunately, that didn't work. When I start these workflows, I can see in the ‘Input’ output that the token is insert, but unfortunately the authorisation does not work.
If I then delete my api.umbrella.com target and create a new one with token authentication (it's really stupid that you can only create a URL once as a target - I have several umbrella tenants that all use the same URL), then this workflow task also works.
Does anyone have such a scenario and was able to solve it?
EDIT
I have deactivated the target ‘Authentication required’.
I then created a workflow for authentication.
In this I have the API key encoded in Base64. This allows me to query the access token from Umbrella and use it in other workflows.
HannesHeinrich
EDIT
@HannesHeinrich  I haven't worked with Umbrella inside of Workflows and I don't know of anyone else that has either so I don't have an answer to your question at this time.  The good news is that later this year, likely around Cisco Live US, a native adapter for Cisco Umbrella as a Workflows target should be available.
HannesHeinrich
EDIT
