CURL recipes for activating / deactivating WebEx accounts using WebEx URL API
Saqib Ali
Greetings,
Can I get some examples of using CURL to activate / deactivate WebEx accounts using the WebEx URL API?
Thanks!
nick.mueller
Level 6
Level 6
WebEx XML API may be a better bet. The XML API examples include some XML that gets you most of the way there.
Nick,
Can you give me examples / links to use the XML API?
Thanks!
