Ansible - sftp transfer mechanism
Netmart
When Ansible is trying to connect to host [Cisco Cat 6, the following error message appears:
[WARNING]: sftp transfer mechanism failed on [172.16.1.1]. Use ANSIBLE_DEBUG=1 to see detailed information
Below you will find an extract of debug log:
2084530 1702194010.51532: variable 'ansible_host' from source: host vars for cisco.switch@cisco.com'
2084530 1702194010.51624: Set connection var ansible_connection to ssh
2084530 1702194010.51628: Set connection var ansible_pipelining to False
2084530 1702194010.51630: Set connection var ansible_module_compression to ZIP_DEFLATED
2084530 1702194010.51632: Set connection var ansible_shell_executable to /bin/sh
2084530 1702194010.51633: Set connection var ansible_shell_type to sh
2084530 1702194010.51634: Set connection var ansible_user to cisco
2084530 1702194010.51637: Set connection var ansible_timeout to 10
2084530 1702194010.51652: variable 'ansible_shell_executable' from source: unknown
2084530 1702194010.51653: variable 'ansible_connection' from source: unknown
2084530 1702194010.51654: variable 'ansible_module_compression' from source: unknown
2084530 1702194010.51655: variable 'ansible_shell_type' from source: unknown
2084530 1702194010.51655: variable 'ansible_shell_executable' from source: unknow
I would appreciate any help.
M02@rt37
Hello @Netmart
Do you do that as suggested ?
ANSIBLE_DEBUG=1 ansible-playbook your-playbook.yml
This will provide more detailed debugging information, and you may be able to identify the specific reason for the SFTP transfer failure.
Best regards
Attached you will find the debug file.
Here is some extract of it:
2084530 1702194010.51532: variable 'ansible_host' from source: host vars for 'CiscoCat6500.cisco.com '
[WARNING]: sftp transfer mechanism failed on [172.16.0.1]. Use ANSIBLE_DEBUG=1 to see detailed information
Thanks @Netmart for that output.
[WARNING]: scp transfer mechanism failed on [172.28.159.255].
What is this ip ?
Do you check if you can access by ssh the remote equipement from the host you execute this playbook ?
Best regards
