Analog Gateway extract
Ronit Malhotra
I am using call manager 10.5, need to extract analog voice gateway repoet with content
1. IP ADDRESS
2. Name
3. Extension
4. Subunit details
Andrew Skelly
Level 7
Level 7
Have you tried using BAT to Export the Gateway details?  It should give you everything except for the IP address.
Please rate helpful posts by clicking the thumbs up!
Thanks, but need gateway IP address as eell
You can pull that from CUCM.  How many gateways do you have?
On the CLI issue the command "show risdb query gateway"
Copy the output and paste it into a text file (like Notepad++) and save with extension CSV.
Open in Excel.
That should give you a list of all of the endpoints along with their individual name, IP , etc. You could sort on the gateway name column to show which ones are on the same router.
If your v10.5 CUCM doesn't like that command, it might not be available until a later version. You can run "show risdb list" to get a list of reports you can run.
Maren
