Auto Upgrade in Cisco Control Hub
Abdul Kalam A
Is there a way to disable auto software upgrade in Cisco Control Hub?
Not from what I know. You can set the update cadence to a custom setting, but that’s about all that I know of. If you reach out to your Webex CSM he/she should be able to tell you if there are other options present.
If I may ask, why do you want to turn this off?
Response Signature
