BiB (Built-in-Barge) and Silent Call Monitoring
alanhow2007
Would like to explore on using use BiB (Built-in-Barge) and Silent Call Monitoring without UCCE/UCCX possibility. If this able to configure on the CUCM only. If yes, how to do about it. What will be the alternative to have this features without without UCCE/UCCX
Jaime Valencia
Without any proper monitoring solution, all you can use is barge to conference you into the call if you have a shared line.
java
if this helps, please rate
Hello Jaime,
Would you like to provide the monitoring solutions please?
Thank you,
Alexandros
PTS
If you are open to 3rd party applications then you can checkout below application which provides Silent Monitoring capabilities for Cisco CUCM ( UCCX / UCCE is not requried )
"MARS Silent Monitoring" application
http://www.parsec-tech.com/parsecapplications.html
Please refer attached document
-Silent Monitor Shared Lines/Shared Extensions of Agents
-Silent Monitor all incoming Calls
-Silent Monitor Campaign Dialer Calls
-Silent Monitor manually dialed outbound calls
-Silent Monitor Agent to Agent Call
-Whisper Coaching
-Continuous Monitoring feature
-Monitoring can be initiated via a web based UI
-Monitoring can be initiated via IP Phone service based application in the Cisco IP Phone
-Displays agent phone status (Offhook , Ringing , Busy)
For details you can write to info@parsec-tech.com
www.parsec-tech.com
