Call issue
mukeshrulaniya
Level 2
Level 2
Hello experts,
  I am using cucm 8.6 with public ip . I have demo license on it. i want to test it with two Iphones and these are connected but can't able to call each other but from Iphone to my desktop SCCP CIPC can call. CIPC can't able to call Iphone.
can you please tell me about this issue or m miising something in configuration.
thanks
Mukesh
Chris Deren
Have you elimiated parition/CSS issue?
Chris
Hello Sir,
    I am using the default setting . i have not any partition or CSS.
thanks
Exactly what do you see/hear on the phone when you try to place the call??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Dear sir,
   Now i have CSS and partition. My iphone and CIPC are on same partition and both are registered.
   From Iphone to CIPC call is coming and everything fine but i can't able to call cipc to Iphone. Before as i mention above i have public ip on cucm and  can't able to call Iphone to Iphone.  I am not using any VPN.What is problem of VPN ?
thanks
