Call monitoring cisco jabber
Stewart Thomas
Has anyone ever setup silent call monitoring with Cisco Jabber softphone? If so how did you do it?
Jackson
hitekuma
Hi Stewart,
You can go through the following document to setup the Silent Monitoring and Call Recording on Jabber devices:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/10_6/CJAB_BK_C56DE1AB_00_cisco-jabber-106-deployment-and-installation-guide/CJAB_BK_C56DE1AB_00_cisco-jabber-106-deployment-and_chapter_010010.html#JABW_TK_S2359FBF_00
The above document gives you a brief about the procedure involving appropriate recording/monitoring application. The configuration also depends on which Call Manager version you are using. Let me know if you face any problem with the mentioned configuration.
