Cisco CUBE dtmf and lti
pekoms
I am getting a some new cubes ready and during testing for dtmf I noticed the inbound call leg from sip itsp was always Inband and toward the cloud pbx (sip) was rtp-nte as configured.
Both inbound and outbound dial peers were configured with dtmf-relay rtp-nte.
While testing IVR I could not see any digits at all and IVR would not work.
After I added the LTI configuration:
dspfarm profile 1 transcode
codec g711ulaw
maximum sessions 48
associate application CUBE
Now IVR works.
Questions, is there a better way than LTI to get dtmf to work?
Is the transcoder only invoked when it is needed?
I expect to have approx 400 calls during peak time so am wondering if during the call the transcoder is used and then released?
b.winter
as long as one of the 2 connected parties doesn't support the DTMF method of the other one, then you will always need a device, which does the DTMF conversion. In your case it's CUBE.
The transcoding resource is only used, as long as a call lasts, which needs a transcoding resource.
In your case, because you have this DTMF problem, probably every call will need a transcoding resource.
