Cisco ISR 4321 SBC for MS Teams Direct Routing
cloudfire
Hi, we'tring to testing the direct routing offered from MS Teams using a Cisco ISR 4321. We've followed this guide:
https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise/interoperability-portal/direct-routing-with-cube.pdf
The unique difference is that we haven't user the procedure of requesting a new certificate through thc CSR but we've imported a third party wildcard certificate.
The problem is that the Cisco router and MS teams don't communicate at all (TLS and SIP are inactive). We've already checked the licensing, the certificate validity, the domain and so on.
Someone have already done a succesful intergation between Cisco ISR and Teams Direct routing that can help us.
I can provide the router configuration and logs and also the pcap traces.
Thanks for help
Alberto.
Ibrahima DIALLO
Hi Alberto,
Please try to change the revocation-cehck for Baltimore trustpoint to none
crypto pki trustpoint baltimore
enrollment terminal
revocation-check none
Ibrahima
Hi Ibrahima, thanks for your reply. I've already solved the problem that was the certificate upload.
We modified the key encryption, add a protection passoword on that and re-uploaded the certificate using this command:
crypto pki import XXX pem terminal password
After that the SBC is registered correctly.
