Cisco Jabber 11.5.0 will not reset
glenn.kelloway1
The Jabber will not reset to allow me to configure the "Advanced Settings."  Whenever I select the "reset" button, the spinning wheel is displayed and goes away with out reset the configurations.  I am prompted with a message saying "The telephony configuration settings are invalid."
I am able to reset Jabber when open the program using my super-user credentials.  I can configure the software to the desired setting but when i open the software up with the local login, Jabber still has the old settings.
Jonathan Unger
Level 7
Level 7
Hi Glenn,
It would be helpful if you could post your jabber client troubleshooting log (Help > Report a problem) after you receive the error message.
I was able to figure out the problem.  Single sign-on was enabled by our head quarters without us knowing.  Once the single sign-on settings were updated to meet the requirements for our location, jabber worked properly.
Thank you,
Glenn
