03-23-2016 06:55 AM - edited 03-17-2019 05:58 PM
The Jabber will not reset to allow me to configure the "Advanced Settings." Whenever I select the "reset" button, the spinning wheel is displayed and goes away with out reset the configurations. I am prompted with a message saying "The telephony configuration settings are invalid."
I am able to reset Jabber when open the program using my super-user credentials. I can configure the software to the desired setting but when i open the software up with the local login, Jabber still has the old settings.
03-29-2016 11:43 PM
Hi Glenn,
It would be helpful if you could post your jabber client troubleshooting log (Help > Report a problem) after you receive the error message.
04-14-2016 07:43 AM
I was able to figure out the problem. Single sign-on was enabled by our head quarters without us knowing. Once the single sign-on settings were updated to meet the requirements for our location, jabber worked properly.
Thank you,
Glenn
