Cisco Jabber 11 Remote Mobile Access Deployment issue no voice is coming after call is connected
ahmedzone
Level 5
Level 5
I have configured Cisco Jabber 11 with RMA it is registered properly IM & Presence and CUCM services are coming but when I dail a call it connects but no voice is coming.
Suresh Hudda
Is NAT reflection is configured at firewall ? Or you can analyze pcap in expressway in case of any port block at network.
Suresh
Suresh Hudda
Suresh
Rajkumar Yadav
Level 4
Level 4
Hi Ahmed,
Did you opened the port 2222.
As well the ports 36000 / 36001* or 2776 / 2777**
Please refer the firewall configuration guide for port to be open.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-7/Cisco-Expressway-IP-Port-Usage-for-Firewall-Traversal-Deployment-Guide-X8-7.pdf
For testing purpose you can check which ports are getting blocked while re creating the issue.
Raaj.
ahmedzone
Level 5
Level 5
I found same solution issue NAT was missing in External interface.
