01-21-2020 09:47 AM
Jabber 12.7.1 or higher for Windows or Mac:
Seeking help from the community if you know of a way to set the default Webex meeting notification toast to default to Webex as the option instead of Jabber.
With the newer release of Cisco Jabber, the join button is no longer separate as users are now offered just a single green Join button. From the single join button users can click on the little drop down arrow to select Jabber or Webex.
We would like to change the default to be Webex.
There doesn't appear to be a parameter we can set in the jabber xml to achieve this. Does anyone know of a possible hidden parameter? Any help greatly appreciated.
11-27-2020 01:00 PM
I saw this in searching for a solution...Set Jabber to "Join in Webex" by default for meetings - Cisco Community
but I can't even get ours to work.. XML config old. so likely missing things.
12-02-2020 06:12 AM
from UC services configure the port number transport layer information
