Cisco Jabber cannot call - register via expressway Edge
bayu00001
Dear Guys,
Anyone can help for this issue :
we wait for your advice
many thank
regards,
bayu
Manish Gogna
Hi Bayu,
Please check the following link and verify the conig accordingly
http://www.cisco.com/c/en/us/support/docs/unified-communications/expressway/118798-technote-cucm-00.html#anc13
Manish
- Do rate helpful posts -
Hi Manish,
Jabber is succesfully login and have ext via expressway,
if call from external jabber via internet , not hear voice call and reject after 30 second.
For no Media When You Call Through MRA the following can be an issue:
In a single NIC deployment with NAT configured, these parameters are either missing or not configured correctly:
  • Expressway-C is not pointed to the Public IP address of Expressway-E, which allows the firewall to hairpin the signaling.
  • If pointing to the FQDN of Expressway-E for TLS, verify the FQDN must resolve to the Public IP Address of Expressway-E.
  • These are not configured on Expressway-E:
    xConfiguration Ethernet 1 IP V4 Address: "<Internal_IP>"
    xConfiguration Ethernet 1 IP V4 StaticNAT Address: "<Public_IP>"
    xConfiguration Ethernet 1 IP V4 StaticNAT Mode: "On"
Hi Manish,
today i have implement on my expresssway E using dual NIC deployment.
but still cannot hear voice and video.
I have follow your suggesstion using NAT on expressway E via CLI command, but is same.
please your advise and suggestions
thanks
