11-27-2018 07:52 AM - edited 03-17-2019 07:47 PM
I was wondering if anyone knew if it were possible to edit fields in the Jabber info menu, for example, say one of the fields in the below photo such as chat address or Work.
Would it be possible to change these to different fields to reflect other info, say secretary ? The info is all in AD of course but I can't seem to find any field mappings around IM&P.
Thanks in advance!
Solved! Go to Solution.
11-27-2018 08:08 AM
If you mean the name of the fields as they're shown, you cannot add/remove/modify the fields/labels.
If you mean change the LDAP mapping for each field, you do that via the .xml
11-27-2018 08:08 AM
11-27-2018 08:10 AM
