11-20-2014 01:08 PM - edited 03-17-2019 04:40 PM
Hi - I had a general question about caller ID from Cisco MeetingPlace 8.x
We have a 5 digit pattern set up to send to Cisco MP - i.e. 38888. The call gets routed to the correct bridge, but on the return SIP signaling, the P-Asserted-Identity header displays "Cisco Unified Meetingplace 0000." I've found where you can change this, but I need more customization.
Ideally, we'd like the 5 digit bridge number, 38888, inserted into the PAI header so it will be displayed on all phones. Our other phone systems read caller ID from the PAI header.
Is this a simple meetingplace meeting configuration item, or will we have to do specific header manipulation to support this?
Dan
Solved! Go to Solution.
11-21-2014 05:36 AM
Hi Dan,
The only place where you can configure something like this on MeetingPlace is in Admin > System Configuration > Call Configuration > SIP configuration section under Display Name and User Name (and I am sure you already found this).
Unfortunately, there is no other way to customize anything related to this on MeetingPlace side, and as you've mentioned, you will most likely have to do this on CUCM side.
Kind regards,
-Dejan
11-21-2014 05:36 AM
Hi Dan,
Kind regards,
-Dejan
11-24-2014 05:54 AM
Thanks Dejan. I appreciate the quick response. I was hoping there was another place to modify this.
