Cisco Prime collaboration for advanced part number
yeruel77
Hi Team,
I just want to order for cisco prime colllaboration advanced. please share me part number for this order.
Jaime Valencia
If you're with a partner, you should be reaching PH for this question, also, you're posting in the Jabber Clients/Jabber Guest forum. There's an area dedicated to Prime Collaboration.
java
if this helps, please rate
