Cisco satellite certification error (HTTPS)
Gura24
Level 4
Level 4
after registration successfully of cisco satellite server I still have a certificate issue (https error) in my browser.
I can't find anything in cisco documents to fix that issue. I will be very appreciate if someone can help!
Thank you!
You install the certificate where you need to authenticate the server certificate upon ssl handshake.
java
if this helps, please rate
Jaime Valencia
Try installing this root CA and make sure to use the CN/SAN from the satellite certificate when browsing to it.
https://www.cisco.com/security/pki/certs/clrca.cer
java
Thanks for response!
One more thing, how I can install the rootCA on Satellite? Via CLI? Do you have some cmd?
Thank you!
java
one more thing. The version of SSMS 7.201910 seems to be broken, if you install the version of 7.202001 then you can generate a CSR certificate.
All fine, thx for help!
cheers,
