Showing results forĀ
Search instead forĀ
Did you mean:Ā
CMS Core and Edge Can't Make a Call
Colinzhong
Hi ,
I just built CMS Core and Edge. The trunk connection is ok and I am able to login CMA and WebRTC from the Internet but it seems that a call to space or a people can't be made between internal can external. I can't see video comes up from the remote side. I am told that there is no license needed for the Edge server. it works fine when I tested WebRTC with my Expressway(1800 TURN).
So I guess TURN license on Edge is required?
any help is appreciated!
Patrick Sparkman
Duplicate post, recommend you delete this one, as the other is already solved.
CMS Core and Edge Can't Make a Call in TelePresence section of the forums.
Patrick Sparkman
