09-18-2017 03:20 PM - edited 03-17-2019 07:05 PM
Hi ,
I just built CMS Core and Edge. The trunk connection is ok and I am able to login CMA and WebRTC from the Internet but it seems that a call to space or a people can't be made between internal can external. I can't see video comes up from the remote side. I am told that there is no license needed for the Edge server. it works fine when I tested WebRTC with my Expressway(1800 TURN).
So I guess TURN license on Edge is required?
any help is appreciated!
Solved! Go to Solution.
09-19-2017 05:12 PM
Duplicate post, recommend you delete this one, as the other is already solved.
CMS Core and Edge Can't Make a Call in TelePresence section of the forums.
09-19-2017 05:12 PM
