CMS customization ivr branding
NicolasTirard
I'm actually deploying a CMS solution using the Callbridge service only.
i'm trying to get some customization on the ivr (background image, welcome voice, etc...) and when i do the configuration of the new ivr_background.jpg via postman, I get a 200 responce but when checking with a GET, I dont see the resourceLocation.
<?xml version="1.0"?>
<ivrBrandingProfiles total="5">
<ivrBrandingProfile id="30645f65-51c8-4f64-bf60-7b71824235c0">
<resourceLocation></resourceLocation>
</ivrBrandingProfile>
Also when trying to get this profile assigned to an ivr, I use the get://..api/v1/ivrs api but it return an empty results, while I've configured one on the CMS webpage under Configuration/General/IVR/IVR Numeric ID
<ivrs total="0"></ivrs>
What am I doing wrong? I have to say that I'm new to API, and I've been following the Customization-guideline doc, but it doesn't cover all options.
nicolas
NicolasTirard
Fixed:
This was an issue with the format of my API request (with POSTMANN) which should have been under the format x-www-form-urlencoded
NicolasTirard
Fixed:
