11-26-2018 11:12 AM - edited 11-26-2018 11:13 AM
Hi Guys
pls have a look below , i didnt use port 445 anywhere in CMS but getting
FAILURE: Ports in use by other services
CMS> webbridge
Enabled : false
Interface whitelist : a:445
Key file : webbridge.key
Certificate file : webbridge.cer
Trust bundle : callbridge.cer
HTTP redirect : Enabled
HTTP URL redirect : true
Clickonce URL : none
MSI download URL : none
DMG download URL : none
iOS download URL : none
CMS> webbridge enable
SUCCESS: Key and certificate pair match
CMS> webadmin
Enabled : true
TLS listening interface : a
TLS listening port : 443
Key file : webadmin.key
Certificate file : webadmin.cer
STATUS : webadmin running
CMS>
thanks all
11-27-2018 05:25 PM
It is typically a best practice to use 445 for webadmin and 443 for webbridge. The idea you don't want your end users having to enter a port but your admins should be trusted to be able to understand the need for the port. Have you tried reversing these.
If 445 is not used anywhere else your error message is indeed odd.
11-28-2018 03:46 AM
thanks mate
