CMS Rerouting problem
robert.klopsch
Hi Guys,
I have a problem with rerouting in a CMS CallBridge Cluster.
The cluster consists of 4 CMS CallBridges.
There are 4 trunks (circular) from the CUCM to the CallBridges.
CallBridge Grouping is activated.
example space: Name CFB1; URI user part 400000
The rerouting itself works fine, but the line presentation label looks not that customer-friendly.
If the call goes over the first trunk to the first Callbridge (no rerouting takes place)
the label of a TC Endpoint (EX90) looks like: 400000@companyname.com
the label of a CE Endpoint (DX80) looks like: 400000@companyname.com
If the call goes for example the second trunk to the second Callbridge (rerouting takes place)
the label of a TC Endpoint (EX90) looks like: 400000@callbridge02.companyname.com
the label of a CE Endpoint (DX80) looks like: CFB1
Particularly in the CE Software of a DX80 system it looks not that customer-friendly.
It would be really cool, if it would be possible to get every time the label CFB1.
thank you in advance
Patrick Sparkman
Recommend opening a case with TAC, this could be a bug where the display name doesn't appear correct, or it could be worked as expected.
