CMS vmware Dployment dont work
Daniel Flieth
Hi, when i want to install a new Cisco MeetingServer and then start the VM, i only get message from Console "#############################
Cisco Systgems Inc. Cisco Meeting Server (CMS)
Nothing more happens.
Does anybody know why this happens?
9 Replies 9
Jaime Valencia
Are you installing CMS on supported HW, that has enough resources for your VM configuration, and over a supported ESXi release?
What CMS version?
java
if this helps, please rate
Hi Jaime,
it runs on a Cisco UCS C220 with 2x E5-2630v3 and 32 GB RAM.
It is the only machine on this host.
I attached the output from the VM. This stays forever.
CMS version?
And what are the specs of the CMS VM you deployed?
java
I tried with 4gb ram and 4vcpus but also with 8 ram and 8 vcpus. Always the same .
I tried with Version 2.2.5 and 2.2.8..both the same...
I dont see the issue. The Specs should be ok but nothing happens.
Attached the CMS Settings in the VM
Does anybody have an idea?
Hi Daniel,
One time I have same problem with CMS console at first installation and i spent long time to resolve  problem.
Please try another PC to connect ESXi and CMS Console .
Maybe same case and it help you.
And the ESXi Host
