Collab Edge mobile Jabber - which Edge device am I on?
wrhale
How do you see which Cisco Expressway the Jabber mobile client is connected to?  When I look at IM and phone services, the phone is showing the server names for CUCM and CUPS, but I'm on my network at home and am not using VPN on the phone.
Jaime Valencia
I don't believe you can see that directly in the client, the windows client would show that under health.
You would need to look at a PRT to see which SRV you got, or log into CUCM admin, the device will show the IP from the EXP-C that is proxying his registration.
java
if this helps, please rate
